Home > Maintenance & Modifications > My castor issue!
bear100
My castor issue!
I think Ive dropped a bol**k!
I’ve bought a new set of powder coated radius arms, but didn’t realise they were the 3” castor corrected versions Shocked I have a 110 utility on standard height springs (3 years old) and fox shocks which handles well.
I’ve also bought at Billing show a new set of uprated heavy duty standard trailing arms from Gwyn Lewis
If I fitted the new radius arms to what I have now what are the issues?
Should I upgrade to a 1” or 2” lift?
We use the 110 for expeditions and camping trips, mostly road use but do travel the Pyrenees, alps, Morocco is on the cards soon. It can be fully loaded (I’m one of those must have all the gear no idea types!!) 2023 Defender L663 V8
2010 110 XS Utility 2.4TDCI
1993 110 csw 200 tdi (gone)
1994 90 HT 300 tdi (gone)
1994 discovery 300tdi (gone)
90 hybrid 3.5 v8 (gone)
Post #1070853 4th Jul 2025 6:26pm
jimbo55
I’ve been running 3deg radius arms and cranked trailing arms for the last 4 years on my 90 and it’s lowered 1” without issue, the cranked trailing arms put the bush in a neutral position
Depends what you do with your 110 and what tyres you want to fit etc. if a lift is actually needed or an upgrade for you
Post #1070866 4th Jul 2025 9:47pm
bear100
Thanks Jim, I think I will fit them and see how it goes, I like the look of the lifted defender but it does affect the the ride……see how it goes
Thanks 2023 Defender L663 V8
Post #1070912 5th Jul 2025 7:44pm
