![]() | Home > Maintenance & Modifications > My castor issue! |
jimbo55 Member Since: 15 Jul 2020 Location: Midlands Posts: 408 ![]() ![]() |
I’ve been running 3deg radius arms and cranked trailing arms for the last 4 years on my 90 and it’s lowered 1” without issue, the cranked trailing arms put the bush in a neutral position
Depends what you do with your 110 and what tyres you want to fit etc. if a lift is actually needed or an upgrade for you |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 2027 ![]() ![]() ![]() |
Thanks Jim, I think I will fit them and see how it goes, I like the look of the lifted defender but it does affect the the ride……see how it goes
Thanks 2023 Defender L663 V8 2016 Range Rover Autobiography 4.4 TDV8 (gone) 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
