![]() | Home > Maintenance & Modifications > Bumper bolts? |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1789 ![]() ![]() ![]() |
If I was a gambling man, I'd say they're the bolts in the bag in your picture!
From memory they're M10* 130 or similar for use bolting in JATE rings |
Baz8046 Member Since: 08 Feb 2016 Location: Chatham Posts: 85 ![]() ![]() ![]() |
Have just replaced these on mine whilst refurbishing my winch tray.
They are M10 120mm and fit in the existing chassis holes. ![]() Click image to enlarge ![]() Click image to enlarge Defender Td5 Commercial 2002 Range Rover L322 TDV8 Westminster 2012 Discovery 4 SDV6 Landmark 2016 |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8463 ![]() ![]() ![]() |
I expect you currently have bolts there for the lashing eyes. Depending on how the winch tray sits amd width of rear braces and whether ypu wish to retain the lasing eyes will determine if you can use existing bolts or replace them with longer ones. Cheers
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6040 ![]() ![]() |
As above. It’s where the standard lashing point bolts.
breadturbo Member Since: 30 Mar 2025 Location: West Yorkshire Posts: 15 ![]() ![]() ![]() |
awesome, thankyou folks
Another question if i can folks, I have fitted it however i had to chop a bit off the 'grille surround?' (you can see the bit in pic)
![]() Click image to enlarge Now with the bumper on the rear winch mount bolts are under the remaining bit of grille surround, should i also just chop this off and remove some grille fins? its floppier than a 5.25" so should not affect anything i think, just seems odd to have to remove so much. ![]() Click image to enlarge thanks James |
How much, if any, you need to remove depends on the bumper style and winch to be fitted. Sounds like yours is setback for a better approach angle therefore expected some panel trimming to be done. Cheers
