Home > Maintenance & Modifications > Bumper bolts?
breadturbo
United Kingdom 1997 Defender 110 300 Tdi HT Alpine White
Bumper bolts?
Hiya all Smile
My defender came with a winch bumper and winch which i have decided to fit, the front bumper has the normal set of 4 vertical bolts with the captive plates.
There are two extra lower fixings on the winch bumper lower down that are not used on my stock bumper, what bolts go into these?
thanks Smile
Post #1070809 3rd Jul 2025 11:24pm
miker
If I was a gambling man, I'd say they're the bolts in the bag in your picture!
From memory they're M10* 130 or similar for use bolting in JATE rings
Post #1070812 4th Jul 2025 1:28am
Baz8046
United Kingdom 2002 Defender 90 Td5 HT Rutland Red
Have just replaced these on mine whilst refurbishing my winch tray.
They are M10 120mm and fit in the existing chassis holes.
 Defender Td5 Commercial 2002
Range Rover L322 TDV8 Westminster 2012
Discovery 4 SDV6 Landmark 2016
Post #1070839 4th Jul 2025 2:38pm
jst
I expect you currently have bolts there for the lashing eyes. Depending on how the winch tray sits amd width of rear braces and whether ypu wish to retain the lasing eyes will determine if you can use existing bolts or replace them with longer ones. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1070850 4th Jul 2025 6:01pm
landy andy
As above. It’s where the standard lashing point bolts.
Post #1070887 5th Jul 2025 6:58am
breadturbo
awesome, thankyou folks Smile
Post #1070904 5th Jul 2025 3:29pm
breadturbo
Another question if i can folks, I have fitted it however i had to chop a bit off the 'grille surround?' (you can see the bit in pic)
Now with the bumper on the rear winch mount bolts are under the remaining bit of grille surround, should i also just chop this off and remove some grille fins? its floppier than a 5.25" so should not affect anything i think, just seems odd to have to remove so much.
thanks
James
Post #1070931 6th Jul 2025 6:12pm
jst
How much, if any, you need to remove depends on the bumper style and winch to be fitted. Sounds like yours is setback for a better approach angle therefore expected some panel trimming to be done. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1070934 6th Jul 2025 7:54pm
