Home > Technical > Puma column stalk wiring help needed
milan
Hi all,
I have just received a column stalk which I believe it’s from a Puma (definitely post 1997) with wipers/indicators/lights.
It’s going into a custom Defender build with non standard electrics and I am struggling to find any information on the wiring for the stalks/pinouts etc. Any information will be gratefully received. I’m attaching pictures of the stalks.
Many thanks,
Milan
Post #1070602 30th Jun 2025 7:03pm
Ianh
Here are the wiring diagrams for the 2.4 Puma https://www.lrworkshop.com/wiring-diagram/....4tdci-rhd
You have side and headlamps, dim dip, horn, indicators, front wipers and washer jet.
Post #1070604 30th Jun 2025 7:51pm
milan
Thanks Ianh - I spotted these before but bounced because there seems to be a mismatch of the wire colours - but maybe it’s me I do have yellow/green colour blindness I’ll try again Smile
Post #1070608 30th Jun 2025 8:51pm
Just a minor tip as well, be careful not to over tighten the securing screw on the collar that goes around the column, as it can crack if not at first over time and then everything can get loose. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1070610 30th Jun 2025 9:11pm
