![]() | Home > Technical > Puma column stalk wiring help needed |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2516 ![]() ![]() |
Here are the wiring diagrams for the 2.4 Puma https://www.lrworkshop.com/wiring-diagram/....4tdci-rhd
You have side and headlamps, dim dip, horn, indicators, front wipers and washer jet. |
milan Member Since: 30 Dec 2024 Location: Newport Posts: 10 ![]() ![]() |
Thanks Ianh - I spotted these before but bounced because there seems to be a mismatch of the wire colours - but maybe it’s me I do have yellow/green colour blindness I’ll try again
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20967 ![]() ![]() |
Just a minor tip as well, be careful not to over tighten the securing screw on the collar that goes around the column, as it can crack if not at first over time and then everything can get loose. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
