Home > Puma (Tdci) > Oil everywhere
Page 2 of 2 <12
Johan_B
Sweden 2007 Defender 110 Puma 2.4 CSW Tonga Green
Smile
Pictures are from after cleaning up but I admit the thread title is by now a bit misleading. It originates from me crawling under the truck in the dark and finding the left side covered in engine oil, axle oil dripping from the diff and the gearbox being wet, which I assumed was from the AC but I now see is some kind of oil.
Anyway, it leaves marks on the ground as soon as it is parked so will need to be addressed before next MOT, even though it is not urgent at the moment.
I am thinking an external clutch fluid leak has to come from this part. Question is, can it be serviced without taking the transmission out? Also JLR parts diagram doesn't show this part, so not sure if it's only as part of a complete clutch change.
But yes, I can commute to work without getting oil stains on my clothes so not a big drama at this point.
Post #1073258 13th Aug 2025 9:05am
That's the clutch slave cylinder adaptor, and is actually two parts (see picture below). The "T"-shaped part connects to the slave cylinder and also incorporates the bleed valve at the outer end, the smaller part below connects the hydraulic line into the adaptor and is a flow restrictor, the purpose of which is to protect the driveline in the event that your foot slips off the clutch or a hydraulic line fails whilst you have the clutch out.
The adaptor is LR031188, the restrictor is UUG500040, and both are listed in the parts catalogue.
The flow restrictor can be replaced without removing the transmission but the adaptor/bleed valve part cannot since it is retained to the slave cylinder by a spring clip like the one visible in the image below on the adaptor where the restrictor fits (if it wasn't, hydraulic pressure would simply pop it out when you press the pedal).
It is possible that the bleed valve is leaking, it may not be tightened up.
Post #1073265 13th Aug 2025 10:33am
Johan_B
Thumbs Up
Thanks! I need to improve my skills searching in the parts catalogue. Embarassed
I will check the bleed valve as a first step.
Post #1073279 13th Aug 2025 1:54pm
Just check it’s closed though, the bleed valve, and not tighten it.
As it is a bit fragile, if not careful. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1073322 13th Aug 2025 9:40pm
andy63
Just having a quick read through this and ill just add this in case it helps or is relevant...
The clutch bleed mechanism on these operates on a 180 degree turn from shut to open.. its a positional thing that takes care of open or closed positions..it cant be tightened down to stop a leak.. if its leaking from the bleed nipple I think it would have to be changed as described above.. a lot of work.😫
Post #1073337 14th Aug 2025 6:51am
Johan_B
Thanks for the help. I carefully checked that the bleed screw was at its end position. Can’t say that it moved so will see if it helped.
Regarding removing axle breather I’ll add this info here for any other newbie to stumble upon it in the future.
Puma axle breather looks like this:
After cleaning:
Now press the red collar down and pull the breather pipe out. No force required.
Post #1073520 17th Aug 2025 7:54am
Page 2 of 2 <12
