![]() | Home > Puma (Tdci) > Oil everywhere |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17939 ![]() ![]() ![]() |
That's the clutch slave cylinder adaptor, and is actually two parts (see picture below). The "T"-shaped part connects to the slave cylinder and also incorporates the bleed valve at the outer end, the smaller part below connects the hydraulic line into the adaptor and is a flow restrictor, the purpose of which is to protect the driveline in the event that your foot slips off the clutch or a hydraulic line fails whilst you have the clutch out.
The adaptor is LR031188, the restrictor is UUG500040, and both are listed in the parts catalogue. The flow restrictor can be replaced without removing the transmission but the adaptor/bleed valve part cannot since it is retained to the slave cylinder by a spring clip like the one visible in the image below on the adaptor where the restrictor fits (if it wasn't, hydraulic pressure would simply pop it out when you press the pedal). It is possible that the bleed valve is leaking, it may not be tightened up. ![]() ![]() Click image to enlarge |
Johan_B Member Since: 20 Sep 2024 Location: Gothenburg Posts: 141 ![]() ![]() ![]() |
![]() Thanks! I need to improve my skills searching in the parts catalogue. ![]() I will check the bleed valve as a first step. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20974 ![]() ![]() |
Just check it’s closed though, the bleed valve, and not tighten it.
As it is a bit fragile, if not careful. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 823 ![]() ![]() |
Just having a quick read through this and ill just add this in case it helps or is relevant...
The clutch bleed mechanism on these operates on a 180 degree turn from shut to open.. its a positional thing that takes care of open or closed positions..it cant be tightened down to stop a leak.. if its leaking from the bleed nipple I think it would have to be changed as described above.. a lot of work.😫 |
Thanks for the help. I carefully checked that the bleed screw was at its end position. Can’t say that it moved so will see if it helped.
Regarding removing axle breather I’ll add this info here for any other newbie to stumble upon it in the future. Puma axle breather looks like this: ![]() Click image to enlarge After cleaning: ![]() Click image to enlarge Now press the red collar down and pull the breather pipe out. No force required. ![]() Click image to enlarge |
