Home > Wheels & Tyres > Garages than can balance Defender wheels?
Feltwell
United Kingdom 2013 Defender 110 Puma 2.2 USW Corris Grey
Has anyone else found that it's hard to find tyre places, or garages, that can balance Defender wheels?
Mine has a bit of a shake at 60-ish, I suspect a wheel is a bit out of balance. It has aftermarket 18" alloys on, but the centres must be the same size as standard wheels I presume. No one seems to have the cones large enough to locate the wheels on their balancing machine.
Think might have to seek out a 4x4 specialist tyre place or perhaps an agricultural tyre merchants, if they have balancing machines!
Post #1070111 21st Jun 2025 4:19pm
Ianh
Most good independent tyre fitters should be able to balance a defender wheel and tyre.
Alternatively you could insert some dynabeads ( the smaller ones) via the tyre valve, re inflate and hey presto the wheel / tyre combo will balance.
Post #1070112 21st Jun 2025 4:52pm
Feltwell
You'd think any place would do it, wouldn't you? Maybe just bad luck but 2 places close to me, both good independents, neither had the large enough cone to do it.
If it's not a widespread problem and just my bad luck that's good to hear! Not heard of dynabeads, will check them.
Post #1070117 21st Jun 2025 9:11pm
Will@LRW
 1997 Defender 110 300 Tdi CSW Alpine White
I recently used a guy in a unit to fit tyres and he then couldn't balance them for that reason.
Never had a problem with the large tyre chain places, who I normally tend to use. LR Workshop
New parts illustrations https://www.lrworkshop.com/diagrams/land-r...ed-corners
Find a Defender's history and spec: https://defender.lrworkshop.com
Post #1070119 21st Jun 2025 10:00pm
