![]() | Home > Wheels & Tyres > Garages than can balance Defender wheels? |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2530 ![]() ![]() |
Most good independent tyre fitters should be able to balance a defender wheel and tyre.
Alternatively you could insert some dynabeads ( the smaller ones) via the tyre valve, re inflate and hey presto the wheel / tyre combo will balance. |
Feltwell Member Since: 01 Aug 2024 Location: Shropshire Posts: 7 ![]() ![]() ![]() |
You'd think any place would do it, wouldn't you? Maybe just bad luck but 2 places close to me, both good independents, neither had the large enough cone to do it.
If it's not a widespread problem and just my bad luck that's good to hear! Not heard of dynabeads, will check them. |
Will@LRW Member Since: 04 May 2019 Location: UK Posts: 231 ![]() ![]() ![]() |
I recently used a guy in a unit to fit tyres and he then couldn't balance them for that reason.
Never had a problem with the large tyre chain places, who I normally tend to use. LR Workshop New parts illustrations https://www.lrworkshop.com/diagrams/land-r...ed-corners Find a Defender's history and spec: https://defender.lrworkshop.com |
