![]() | Home > Technical > Removing County Stripes - 1995 CSW |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 683 ![]() ![]() ![]() |
I removed a set from a 96 Epsom Green last week, had to use a decal removal wheel in a drill.
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3642 ![]() ![]() ![]() |
Little heat will do the job. Mine were extremely weathered, with over 30 years in baking sun, and they pulled off easily. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
300TDi CSW Phil Member Since: 03 Apr 2016 Location: Bracknell Posts: 862 ![]() ![]() ![]() |
Thanks chaps.
I'll start with the heat and peel method (when it comes to it) and if that fails I will pick up the removal wheel. On the subject of the wheel are there any go to ones or conversely steer well clear off versions? 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper. Wide Track Sankey- In bits- Gone to a new home M0XQS |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1733 ![]() ![]() |
Wallpaper steamer. Not joking, once you’ve tried you’ll never use a mop again haha Defender puma dormobile camper
mazza Member Since: 27 Apr 2025 Location: London Posts: 28 ![]() ![]() |
Is it possible to buy a new set of county stripes for a 110?
I have seen what appear to be genuine sets available but you will need deep pockets.
There are also copies available via the likes of ebay and etsy. I have decided that as mine is not so standard anymore to do my own thing and go completely different. 1995 300 Tdi Epsom Green- Slowly Turning into Keswick Green - It's a keeper. Wide Track Sankey- In bits- Gone to a new home M0XQS |
