Home > Technical > Removing County Stripes - 1995 CSW
300TDi CSW Phil
United Kingdom 1995 Defender 110 300 Tdi CSW Epsom Green
A question for the knowledgeable people on here....
I am planning on a repaint and need to remove the County Stripes down thes sides(also the TDi etc) from my 1995 CSW.
Can this be done like normal vinyl stickers (heat and care with a plastic scraper) or is another method required due to the age of the existing stickers? 1995 300 Tdi Epsom Green - It's a keeper.
Wide Track Sankey- In bits- Gone to a new home
M0XQS
Post #1070086 20th Jun 2025 9:20pm
Oldowner
I removed a set from a 96 Epsom Green last week, had to use a decal removal wheel in a drill.
Post #1070090 20th Jun 2025 11:43pm
Dinnu
Little heat will do the job. Mine were extremely weathered, with over 30 years in baking sun, and they pulled off easily. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1070094 21st Jun 2025 7:31am
300TDi CSW Phil
Thanks chaps.
I'll start with the heat and peel method (when it comes to it) and if that fails I will pick up the removal wheel.
On the subject of the wheel are there any go to ones or conversely steer well clear off versions? 1995 300 Tdi Epsom Green - It's a keeper.
M0XQS
Post #1070098 21st Jun 2025 10:07am
SailingTom
Wallpaper steamer. Not joking, once you’ve tried you’ll never use a mop again haha Defender puma dormobile camper
Post #1070350 26th Jun 2025 10:31am
mazza
Is it possible to buy a new set of county stripes for a 110?
Post #1071049 8th Jul 2025 9:50pm
300TDi CSW Phil
I have seen what appear to be genuine sets available but you will need deep pockets.
There are also copies available via the likes of ebay and etsy.
I have decided that as mine is not so standard anymore to do my own thing and go completely different. 1995 300 Tdi Epsom Green - It's a keeper.
M0XQS
Post #1071057 9th Jul 2025 7:35am
