Home > Td5 > Whining noise with increasing rpm
Ronan223e
Wales 2002 Defender 90 Td5 CSW Oslo Blue
Just got a 90 02 with 155k. All is good however have noticed a whining noise that increases in volume when increasing rpms. I’m unsure if it’s standard noise for the td5, but would like to check just incase.
The noise is not related to the transfer case. I’m assuming the only possibilities are belt based.
Included a link to a YouTube video of the noise.
Any help would be much appreciated.
https://youtube.com/shorts/GYuYvRChLCQ?si=ilCKeZPwGAMif4y2
Post #1069928 17th Jun 2025 9:03pm
Dinnu
Worth checking power steering fluid level, although low level will usually whine when turning steering wheel.
If thats okay, remove belt and check tensioners and alternator and PAS pump. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1069930 17th Jun 2025 9:09pm
BrickBox
Definitely sounds like a power steering whine to me also. 2017 5.0 V8 Supercharged RRS SVR
2008 2.4 110 Utility Station Wagon XS.
Post #1069935 17th Jun 2025 9:51pm
Ronan223e
Power steering fluid was good.
I don’t notice any change from the noise when steering.
I took the belt off and I believe at least one of the pulleys is bad.
Video attached. Thank you for your help.
https://youtube.com/shorts/fsoNZyRnYu0?si=03U4oJUjzPqkZ3_U
Post #1069939 17th Jun 2025 10:19pm
Screbble
The bearings on the idler pulley don’t sound great. That could explain the noise as that is what I experienced.
If it is that, don’t buy a ‘cheap’ replacement as I did that and the bearings sounded as bad as the old one. Bought an OEM and it was sorted.
Post #1069941 17th Jun 2025 10:32pm
Ronan223e
Cheers for the advice.
I agree I’ll also do both those idlers as the other one doesn’t sound far off
Post #1069943 17th Jun 2025 10:46pm
Screbble
Yes they’re inexpensive enough even for OEM. Worth doing.
Post #1069944 17th Jun 2025 10:59pm
Ronan223e
Hate to ask but being so new to the scene, you don’t know of a good website I could source them from.
TIA.
Post #1069946 17th Jun 2025 11:04pm
Screbble
You’ll find many recommended sellers championed on here.
JGS 4x4 was where I bought mine quite a few years ago, but you can find them on eBay being sold from reputable sellers but do beware of cheap products.
Post #1069947 17th Jun 2025 11:15pm
Ronan223e
Many thanks. Have a lovely night. I really appreciate the advice.
Post #1069948 17th Jun 2025 11:17pm
