![]() | Home > Faults & Fixes (L663) > Rattles and 12 month warranty |
Oneblack Member Since: 14 Oct 2024 Location: Here Posts: 39 ![]() ![]() |
Regarding judder / misfire: I have something similar going on. They found some fault Codes connected to oxygen sensor (lambda probe), having these replaced in 3 weeks.
To me that sounds ds like a reasonable explanation for the judder… |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1455 ![]() ![]() ![]() |
Standard practice for Sytner Northampton…… they are useless…… you have a fight every time you go in…. Even if you’ve booked and waited 3 weeks, they still want to charge you more. I could go on, but Ive better things to do, I wasted enough time with them. Sold the car,
![]() The patronising service receptionist even told me we’d brought the wrong vehicle ![]() ![]() ![]() |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3418 ![]() ![]() |
Unbelievable
Can you not take the vehicle somewhere else? Even if you have to pay. That £240 charge to look at it would be four hours labour at my local Land Rover independent specialist. Probably enough time for a traditional technician to find and cure those faults. |
Jamundo86 Member Since: 24 Oct 2023 Location: Northamptonshire Posts: 25 ![]() ![]() |
Yeah that's the plan - get it looked at elsewhere
They're now ordering a new IDMA (display module) for the screen as apparently it failed a 'PIVI check' - another 2 month wait although covered by the warranty this time. Hoping no CCF changes will get overwritten / defaulted as part of that.. |
