- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
MadTom
Simply press female pins in injector loom a bit more tight and replace 2 orings on the connector between injector loom and car harness. It is quite unussual for injectors to go bad, but bad contacts is not unussual. Because of very bad experience with some pattern made injector looms, I prefer to use the original one with new orings and tighten connector pins. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
19th Jun 2025 7:38am |
