Home > Technical > Identifying a misfire on TD5 using a nanocom
alexatnd
Hi
Got an annoying misfire on startup on my TD5 10p. After a few mins of driving it goes away. Suspect a faulty injector. Have a Nanocom, any pointers as to how to identify which cylinder is having problems ? No fault codes appearing relating to injectors
A Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - new chassis etc back on road
Effie - 2004 110 TD5 County
Post #1069867 17th Jun 2025 7:26am
landy andy
I would think the cylinder balance is the one to look at.
Post #1069869 17th Jun 2025 7:30am
johnlad
Check for oil at the ecu red plug, if present replace injector loom.
Post #1069945 17th Jun 2025 11:00pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Simply press female pins in injector loom a bit more tight and replace 2 orings on the connector between injector loom and car harness. It is quite unussual for injectors to go bad, but bad contacts is not unussual. Because of very bad experience with some pattern made injector looms, I prefer to use the original one with new orings and tighten connector pins. "Drobek" = The Small One - Discovery 2, "BlufĂ­nek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #1070008 19th Jun 2025 7:38am
