Home > Td5 > Replacing clutch slave cylinder
excossack
Is replacing a slave cylinder as simple as,
Remove fluid pipe
Remove the two nuts
Remove slave and leave the pushrod behind
Fit new slave and slide it over the pushrod
Bolt in place
Attach pipe and bleed? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1069809 16th Jun 2025 2:16pm
mrd1990
Wales 2000 Defender 110 Td5 CSW Epsom Green
Yup!
But I would change the master at the same time since (theoretically) they ware out at the same rate Thumbs Up
Post #1069811 16th Jun 2025 2:26pm
excossack
Cheers.
The master was done in April (should have done the slave then) 1999 Defender TD5 110
Regards
John M0VAZ
Post #1069814 16th Jun 2025 2:38pm
rustandoil
Consider a full length braided pipe upgrade from Pioneer 4x4?....
Post #1069816 16th Jun 2025 2:58pm
excossack
Maybe....I hadn't considered that as an upgrade. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1069818 16th Jun 2025 3:02pm
rustandoil
Double post sorry
Post #1069819 16th Jun 2025 3:26pm
rustandoil
You will after you've struggled with the bracket and the rubber hose 😂
Post #1069820 16th Jun 2025 3:28pm
excossack
Words of experience ? 1999 Defender TD5 110
Regards
John M0VAZ
Post #1069822 16th Jun 2025 3:29pm
rustandoil
Triple post sorry
Post #1069825 16th Jun 2025 4:22pm
Screbble
Maybe worth adding the LOF slave to the braided hose upgrade…
Post #1069834 16th Jun 2025 7:02pm
excossack
I already have a new slave to go on Smile but not a LOF 1999 Defender TD5 110
Regards
John M0VAZ
Post #1069835 16th Jun 2025 7:11pm
Screbble
Good luck and keep us posted 👍
Post #1069839 16th Jun 2025 8:12pm
excossack
cheers 1999 Defender TD5 110
Regards
John M0VAZ
Post #1069845 16th Jun 2025 8:40pm
excossack
I decided to order just the short hose to replace the rubber hose. Then its all new stuff.
New master.
New slave.
New flexi hose. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1069880 17th Jun 2025 9:53am
excossack
Well.
The spare I had was FTC5072 which is for TDi/R380.
The one for TD5/R380 is FTC5202 - which I didn’t have. How ever, I remembered there was a Landy parts dealer not from me.
I popped in yesterday afternoon and he was closed. Ended up chatting to the chap in the unit next door from Ultra metalwork - make bulkheads, tubs, doors for land rovers
Anyways, I popped back in this morning and picked up FTC5202 TRW slave cylinder.
I also had the Pioneer4x4 flexi hose which I was going to fit, but trying to remove the hard-line to flexi connector it soon became apparent it could only go one way and something was going to snap. I decided I didnt need any more headaches and managed to remove the flexi hose and metal pipe from the slave.
Removed the two 10mm bolts and as I carefully removed the slave, clutch fluid leaked out from the bellhousing/clutch slave gearbox mount....well that aint right..I think I found the reason why I was losing clutch fluid the bellhousing was drinking it.
Refitted the new one and reattached the metal/flexi hose.
Re-bled the clutch and a quick test drive and it appears OK. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1070059 20th Jun 2025 2:46pm
