Home > Technical > Front Axle Breather tube pathway
Gedd
United Kingdom 1995 Defender 110 300 Tdi HT Rutland Red
I have a 1995 Defender 110 300TDI, the Axle Breather tube for the front Axle has "dropped" down so there is about 1 metre of slack tubing in the nearside wheel arch, its end (u) is just behind the engine, would anyone be able to tell what pathway the tube takes. there are a couple of clips on the slack tube but I cant see where they were attached.
many thanks in anticipation
Post #1069794 16th Jun 2025 12:05pm
They usually run along the nearside radius rod back to the chassis then up the bulkhead slightly to the nearside of centre.
In practice as long as it runs back to the chassis along the radius rod it doesn't really matter where it goes afterwards as long as it is as high as practicable and sheltered from wet.
Post #1069807 16th Jun 2025 2:00pm
Gedd
Many thanks for your reply
Post #1069826 16th Jun 2025 4:48pm
Dinnu
There are a few clips, NRC9246, can use any regular cable to fix to axle tube and radius arm. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1069828 16th Jun 2025 5:23pm
Gedd
Thank you that is what is on the loose tube
Post #1069830 16th Jun 2025 5:46pm
