![]() | Home > Technical > Front Axle Breather tube pathway |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17914 ![]() ![]() ![]() |
They usually run along the nearside radius rod back to the chassis then up the bulkhead slightly to the nearside of centre.
In practice as long as it runs back to the chassis along the radius rod it doesn't really matter where it goes afterwards as long as it is as high as practicable and sheltered from wet. |
Gedd Member Since: 17 Sep 2022 Location: Devon Posts: 14 ![]() ![]() ![]() |
Many thanks for your reply
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3597 ![]() ![]() ![]() |
There are a few clips, NRC9246, can use any regular cable to fix to axle tube and radius arm. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Thank you that is what is on the loose tube
