![]() | Home > Off Topic > Compressor fitting snapped off |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6054
Get some heat on it.
The down side of those extractors that you show is that they try to expand what you are trying to extract. It’s a standard fitting so if you cant get the broken bit out you can just remove the fitting and go again. But they probably have sealant in them that heat will overcome. |
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8486
Quicker to buy another t piece I expect. Cheers
| paul 123 Member Since: 10 Jul 2022 Location: norwich Posts: 150
t piece looks like a standard part take it off and go to a commercial pipe fittings place they will match it or know who can.
This sort of fitting. Obviously you need to know your pipe sizes which are probably imperial.
https://www.plumbingsuperstore.co.uk/produ...gISrvD_BwE |
| Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3892
I never thought the bit left in the cylinder would come out as a whole...I assumed that was welded to the cylinder.
Now next issue I don't have anything to get heat on.... |
