Home > Off Topic > Compressor fitting snapped off
Stacey007
Hello
Moving my trailer round in the garage and snapped off the junction pipe to the compressor with two outlets and the guage on.
There is still some thread in the hole sized
I've tried loads of WD type stuff, sawing it with a junior blade and a thread removal tool.
No luck... Help.....
Is this fixable, it's quite old, given to me by a neighbour a few years back.
Post #1069438 10th Jun 2025 5:58pm
landy andy
Get some heat on it.
The down side of those extractors that you show is that they try to expand what you are trying to extract.
It’s a standard fitting so if you cant get the broken bit out you can just remove the fitting and go again. But they probably have sealant in them that heat will overcome.
Post #1069442 10th Jun 2025 6:55pm
jst
Quicker to buy another t piece I expect. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1069449 10th Jun 2025 8:47pm
paul 123
United Kingdom 1995 Defender 90 300 Tdi HT Auto Rutland Red
t piece looks like a standard part take it off and go to a commercial pipe fittings place they will match it or know who can.
Post #1069468 11th Jun 2025 6:59am
landy andy
This sort of fitting. Obviously you need to know your pipe sizes which are probably imperial.
https://www.plumbingsuperstore.co.uk/produ...gISrvD_BwE
Post #1069471 11th Jun 2025 7:57am
Stacey007
I never thought the bit left in the cylinder would come out as a whole...I assumed that was welded to the cylinder.
Now next issue I don't have anything to get heat on....
Big Cry
Post #1069474 11th Jun 2025 9:24am
