Home > Technical > Oh dear
breadturbo
United Kingdom 1997 Defender 110 300 Tdi HT Alpine White
Oh dear
Cleaned the defender out at the weekend. Forgot to put my tools back in.......
https://youtube.com/shorts/e5e_zlOwKhk?feature=shared
I have spare shafts and end bits in the back, just waiting on my mate for tools lol.
Post #1069348 9th Jun 2025 1:35pm
Mo Murphy
Oh dear indeed ! 😁
50 Shades of Pennine Grey
Post #1069353 9th Jun 2025 3:23pm
breadturbo
Old boy over the road lent me a spanner and I took the rear prop off to get me home in difflock Smile
Post #1069355 9th Jun 2025 3:44pm
Ianh
If it was an old boy I bet it was proper 9/16 spanner’s.
Ps. That’s why I have one piece shafts now. Eliminates that particular issue.
Post #1069356 9th Jun 2025 3:48pm
breadturbo
do they do them for the late salisbury rear?
Cannot find any but my google-fu may be lacking
Ta
Post #1069363 9th Jun 2025 5:39pm
There is always Ashcroft HD 2 piece as well, that’s what I have.
You’ll get good miles from these. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1069367 9th Jun 2025 6:12pm
Ianh
I don’t think single piece shafts are available for the Salisbury axle...but you could weld/ or get someone to weld a 2 piece into a one piece shaft.
Post #1069368 9th Jun 2025 6:18pm
No need to remove the propshaft in that case, just locking the centre diff would have been sufficient.
Post #1069381 9th Jun 2025 10:35pm
breadturbo
Heya,
After a bit of advice if i may Smile
Finally started this today (big mistake kept telling myself it'll get cooler, nah 32c today!)
Anyway, reversed the landy to the end of my drive (had to let the tyres down to squeeze under the carport drained the diff and then took the old shaft out, all easy as pie.
I came to reassemble and the new shaft went wheeee all the way in to a stop about 5mm inside the flange (so no way to put the circlip on)
I compared it to the old shaft, identical lengths(although different seal runners if thats the name and the circlip recess is slightly further down?) but just wanted to check this was how it should be?
Forgot to add, 1997 110 salisbury rear with discs - VA12****
The new and old ones are 640mm roughly, FTC1724+FTC1725 which LRWORKSHOP suggests should be correct
thanks
James
Post #1070025 19th Jun 2025 5:59pm
Johan_B
Sweden 2007 Defender 110 Puma 2.4 CSW Tonga Green
Should be alright. If you look at the old shaft you will likely see that not the full length of splines has been engaged on them either.
In addition to the the length check of the shafts you can also check that the new DMs are not significantly deeper than the old ones.
Your story reminds me of when I lost drive on a previous 110 on which I had replaced the rear shafts. Then it was the splines on the hub side that were too long and allowed the shaft to move out of the differential and loose contact with the gears inside.
Post #1070028 19th Jun 2025 7:19pm
breadturbo
HIya,
thanks for the reply Very Happy
The flanges are both 40mm so everything seems to be identical
can see below why it lost drive
The picture is a bit of a focus fail but you cans ee they are almost worn flat vs the new one!
Post #1070031 19th Jun 2025 7:59pm
