2.4 Puma Oil Cooler
Transferred oil cooler from the plastic oil filter housing type to the metal screw on filter type. All went well with new rubber insert seals. Running fine.
Question is that I noticed that some housings use a steel gasket between the block and cooler housing? Mine (2010) didn’t have one so didn’t fit one when swapping housings. As I say all seems fine but wondered why there is a steel gasket option?
Click image to enlarge2010 2.4 TDCI Puma Defender 90
