Home > Puma (Tdci) > 2.4 Puma Oil Cooler
SilverPuma
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
2.4 Puma Oil Cooler
Transferred oil cooler from the plastic oil filter housing type to the metal screw on filter type. All went well with new rubber insert seals. Running fine.
Question is that I noticed that some housings use a steel gasket between the block and cooler housing? Mine (2010) didn’t have one so didn’t fit one when swapping housings. As I say all seems fine but wondered why there is a steel gasket option?
 2010 2.4 TDCI Puma Defender 90
Post #1069292 8th Jun 2025 1:42pm
hornet
From VINDA444247 onwards they look different and have a different part number which refers to steel.
Post #1069756 15th Jun 2025 5:04pm
SilverPuma
The oil cooler itself looked identical except the screw on filter part. So does the mating surface on the blocks so can’t work out why a steel seal is used on some and just the rubber insert seal on others? 2010 2.4 TDCI Puma Defender 90
Post #1069758 15th Jun 2025 7:17pm
hornet
I guess it was for cost reasons...
I never heard of problems with these (steel) gaskets.
Post #1069952 18th Jun 2025 7:14am
