![]() | Home > Td5 > 110 Salisbury axle prop shaft part number |
Will@LRW Member Since: 04 May 2019 Location: UK Posts: 231 ![]() ![]() ![]() |
https://www.lrworkshop.com/parts/FTC3905
A bit of rotational play is not that big of a deal, although if the play is up and down at the joint (i.e. the prop flexes) then it's less good LR Workshop New parts illustrations https://www.lrworkshop.com/diagrams/land-r...ed-corners Find a Defender's history and spec: https://defender.lrworkshop.com |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6038 ![]() ![]() ![]() |
Thanks Will. What ever the play was the MOT man flagged it up to me. 1999 Defender TD5 110
tom1979 Member Since: 22 Nov 2021 Location: Bedfordshire Posts: 20 ![]() ![]() ![]() |
FTC3905 is the prop you need. https://twinwoods4x4.co.uk/product/defende...y-ftc3905/ ------------- Defender 90 Td5 Discovery 2 Td5 Manual Discovery 2 Td5 Auto Range Rover Classic 300Tdi Bobtail Range Rover L322 M57 (and more- yes I have a problem!) |
Thanks Tom 1999 Defender TD5 110
