Home > Td5 > 110 Salisbury axle prop shaft part number
excossack
Trying to find the part number for a prop shaft for a 110 with a salisbury rear axle. ?
Reason. MOT man mentioned some play in the rear prop shaft and I was weighing up the options of
Replace the prop shaft
or
Replace parts and labour to do the job. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1068991 3rd Jun 2025 10:02am
Will@LRW
 1997 Defender 110 300 Tdi CSW Alpine White
https://www.lrworkshop.com/parts/FTC3905
A bit of rotational play is not that big of a deal, although if the play is up and down at the joint (i.e. the prop flexes) then it's less good LR Workshop
New parts illustrations https://www.lrworkshop.com/diagrams/land-r...ed-corners
Find a Defender's history and spec: https://defender.lrworkshop.com
Post #1069040 3rd Jun 2025 8:53pm
excossack
Thanks Will. What ever the play was the MOT man flagged it up to me. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1069065 4th Jun 2025 7:55am
tom1979
United Kingdom 2000 Defender 90 Td5 HT Caledonian Blue
Re: 110 Salisbury axle prop shaft part number
or
FTC3905 is the prop you need.
https://twinwoods4x4.co.uk/product/defende...y-ftc3905/ -------------
Defender 90 Td5
Discovery 2 Td5 Manual
Discovery 2 Td5 Auto
Range Rover Classic 300Tdi Bobtail
Range Rover L322 M57
(and more- yes I have a problem!)
Post #1069108 4th Jun 2025 9:45pm
excossack
Thanks Tom 1999 Defender TD5 110
Regards
John M0VAZ
Post #1069129 5th Jun 2025 10:01am
