Home > Puma (Tdci) > Headlamp level switch wiring?
mrodey
Sweden 2009 Defender 110 Puma 2.4 CSW Scotia Grey
I have a 2008 2.4 Puma and the previous owner did a real hatchet job on the wiring and I have the headlamp leveling switch (AMR5874) but the wiring in the console has had all the connectors cut off so it's all loose wires.
The wiring diagram for the puma unfortunately doesn't show the pins on the leveling switch of which there are six: 1, 2, 3, 4, E1, E2 (E1 & E2 have a metal bar connecting them).
Does anyone know which is the power in, ground, and lighting contact on the switch?
Post #1068774 30th May 2025 2:37pm
Martin
Site Admin
https://www.lrworkshop.com/wiring-diagram/...-levelling
https://www.lrworkshop.com/connectors/defender-2007/C0093
^^ that view is looking into the plug terminals, so it is the mirror image of looking into the switch terminals.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1068794 30th May 2025 5:40pm
mrodey
Thanks Martin, I have the electrical manuals and looked at the wiring diagram before but I was thinking it couldn't be right since there wasn't multiple outputs for the 0,1,2,3 positions for the headlamp leveling motor.
Post #1068797 30th May 2025 7:33pm
Martin
Site Admin
The position of each motor is controlled down the blue/yellow wires. There isn’t an output for each height Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1068813 31st May 2025 8:00am
mrodey
Martin, that explains why my attempts to figure out the switch positions with my multimeter were fruitless. Thanks for the insight!
Post #1068879 1st Jun 2025 9:10am
