![]() | Home > Puma (Tdci) > Brake pads |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6046 ![]() ![]() |
Shove the links up so we can have a look
Naycrx Member Since: 11 Oct 2023 Location: Nottinghamshire Posts: 176 ![]() ![]() |
Both those links just show a “put your reg in” part finder. Not the pads
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4338 ![]() ![]() ![]() |
I can't help, but when I put my 110 in, I get three Brembo options for the rear! There is a VIN range on 2 of them, which would narrow those down Iguess, and the third option says for a 90. I wasn't aware there was any variation in rear pads on Pumas, but may be 90s are different to 110s?
For the front there are 2 options which I presume are for vented and non-vented discs, but doesn't say which is which. 2007 110 TDCi Station Wagon XS |
Hmmmm Rather Confusing ...At the moment we Have the GreenStuff Pads on With the uprated grooved discs
If you are running Green Stuff ones now I would stay with them
![]() As far as I know there is no difference in vented a non vented pads as the callipers are altered via a spacer. |
Fossil Member Since: 23 Aug 2015 Location: Bolton Posts: 26 ![]() ![]() ![]() |
Front pads are the same 90 and 110. Rears are different, 90s have smaller pistons in different calipers.
great thanks..... I have just been onto 'mymotorworld' they seem to have got it narrowed down ... so only one choice for front and back
