Home > Maintenance & Modifications > Front door check strap
kyvlle
United Kingdom 2004 Defender 110 Td5 XS CSW Epsom Green
Hey all, got an issue with my driver side door check strap that I'm trying to fix.
The posts I've read here point to it have 3 bolts, but mine only has two. Same on the passenger side. This is on a 2005 Td5 110. Is this something common for post-2002 Td5 models?
Anyways, the problem is obvious -- the captive nut for the right side bolt hole has gone missing. What's a possible fix for this? Use a rivnut?
Post #1067631 13th May 2025 8:49pm
Screbble
Yes I’d use a Rivnut.
Good luck šŸ‘
Post #1067745 15th May 2025 7:44am
rustandoil
Rivnut should work a treat....hit that rust with a bit of Kurust while youre there Thumbs Up
Post #1067747 15th May 2025 7:58am
kyvlle
Thank you! Couple more small jobs to go about then.
Post #1067864 15th May 2025 11:27pm
Screbble
Good luck and enjoy šŸ‘
Post #1067881 16th May 2025 8:04am
