Home > Off Topic > Any washing machine repair people on here?
Page 3 of 3 <123
Dinnu
You could make a new spider from some stainless steel angle bar. Its not as difficult as it seems and you will have a machine that will last you a lifetime. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1069253 7th Jun 2025 3:11pm
lightning
You probably could. But you'd have to get the drum shaft off the old spider and then machine the centre of your replacement to take the shaft, and somehow bond it so it didn't come off.
Post #1069319 8th Jun 2025 7:17pm
excossack
The old machine is now at the tip. I took it apart to get it in the car.
I asked the chap at the tip should I put the plastic parts in the plastic skip and metal in the metal.
He said, put it all in the metal skip!
I kept the drum with a plan to make a fire pit out of it 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1069343 9th Jun 2025 10:47am
Dinnu
Actually have done it…
Breaking the remaining spider off the shaft was the easiest bit.
Marked the center of the drum, fabricated a ‘sleeve’ that fits over the shaft, where the original spider used to be.
Positioned the sleeve over the center of the drum, and weld the new spider legs to it.
Weld the original shaft to the sleeve.
After welding, drum wobbled a bit where the welding contracts from the heat, but some persuasion with a mallet got it good enough. Still doing the job 5-6 years later.
Is it worth doing? Only if you have a high end machine with good quality components, and a few free hours. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1069362 9th Jun 2025 5:37pm
Page 3 of 3 <123
