Home > Wheels & Tyres > This might be a dumb question
RRUK
So, would a 1993 standard Defender with steel wheels be able to swap to Boost alloys? I know the alloys need different nuts but wondered if there’s any issues with the studs or fitting over the hubs etc?
I think I know the answer but…. Best to check with the masses.
Thanks for any answers 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #1067495 11th May 2025 6:15pm
jonny
If the drive flanges are standard, then yes, it should fit just fine.
If you have heavy duty (aftermarket) drive flanges, the wheels will fit, but the centre caps won't...
Post #1067501 11th May 2025 7:08pm
Dinnu
1993 would still be a 200tdi, which I think is still 10 spline axles with larger drive member. If that is correct, you would need spacers (30mm). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1067502 11th May 2025 7:19pm
RRUK
So, 2 contradictory answers!
Still confused 2016 D4 HSE
Post #1067607 13th May 2025 4:32pm
Grouse
This may assist :-
https://www.web-rover.co.uk/nav.php?p=articles/alloys
Whilst the drum brake element won’t be relevant - the front axle element maybe, if so the same should apply to the rear axle on a 200
Post #1067609 13th May 2025 4:57pm
Whirly90
England 1993 Defender 90 300 Tdi HT Keswick Green
The 200tdi started with 10 spline axles with drums so alloys won't fit without spacers, the axles were changed in 1993 for 24 spline axles with discs so the alloys should bolt straight on.
Post #1067613 13th May 2025 5:19pm
mini Anaconda
I have freestyle alloys on my 1989 Ninety (disc brakes on the front, drums at the rear) - they fit fine without spacers, but the centre cap won't fit as shown below. Assume it would be the same situation for boost alloys.
 BORG - Bucks & Oxon 4x4 Response Group
Post #1067615 13th May 2025 5:29pm
RRUK
Ok I think I’ve got the answer now.
It’s a 93 200Tdi with discs on the rear too so think it’s 24 spline and they’ll be fine 2016 D4 HSE
Post #1067638 13th May 2025 10:12pm
jonny
If you measure how much the caps stick out from the mounting face on the hub, I'll have a measure of the set of boosts that I have kicking about which should give you a definitive answer.
Post #1067825 15th May 2025 6:38pm
