![]() | Home > Wheels & Tyres > This might be a dumb question |
jonny Member Since: 10 Mar 2013 Location: North Wilts Posts: 243 ![]() |
If the drive flanges are standard, then yes, it should fit just fine.
If you have heavy duty (aftermarket) drive flanges, the wheels will fit, but the centre caps won't... |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3643 ![]() ![]() ![]() |
1993 would still be a 200tdi, which I think is still 10 spline axles with larger drive member. If that is correct, you would need spacers (30mm). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2038 ![]() ![]() |
So, 2 contradictory answers!
Still confused 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 537 ![]() |
This may assist :-
https://www.web-rover.co.uk/nav.php?p=articles/alloys Whilst the drum brake element won’t be relevant - the front axle element maybe, if so the same should apply to the rear axle on a 200 |
Whirly90 Member Since: 01 Sep 2016 Location: Ampshire Posts: 412 ![]() ![]() ![]() |
The 200tdi started with 10 spline axles with drums so alloys won't fit without spacers, the axles were changed in 1993 for 24 spline axles with discs so the alloys should bolt straight on. |
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 844 ![]() ![]() |
I have freestyle alloys on my 1989 Ninety (disc brakes on the front, drums at the rear) - they fit fine without spacers, but the centre cap won't fit as shown below. Assume it would be the same situation for boost alloys.
![]() Click image to enlarge BORG - Bucks & Oxon 4x4 Response Group ![]() |
Ok I think I’ve got the answer now.
It’s a 93 200Tdi with discs on the rear too so think it’s 24 spline and they’ll be fine 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
If you measure how much the caps stick out from the mounting face on the hub, I'll have a measure of the set of boosts that I have kicking about which should give you a definitive answer.
