Home > For Sale & Wanted (L663) > [SOLD] OCTA Side Vents
Q86ARR
I have for sale a pair of OCTA side vents. Removed from a new vehicle as it had twin raised air intakes installed
These retail at £263 each and currently on back order
I will take £250 for the pair posted ono
Post #1067095 5th May 2025 7:55pm
JOW240725
Is it not worth keeping, should you ever remove the snorkels and return to original? Maintain value. James
Instagram @suffolk_rovers
Post #1067150 6th May 2025 1:10pm
lightning
Trying to decide if these would enhance the look of my Tasman Blue D250 Commercial. Anyone know how they are attached and how easy it is to change them?
Post #1067590 13th May 2025 10:36am
ruben
Spain
I think they can look very good..only remember that this are both functional and you, in your D250, have one of them covered, you should find a way to keep it that way...That's your biggest obstacle I think!! Although they may not be in a block, it is only the grille cover, I am talking nonsense!!🫨
Good luck! Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE
Post #1067596 13th May 2025 1:16pm
Bigtym
Re: [For Sale] OCTA Side Vents
Is collection possible? If so wheres the location. Thanks
Post #1067736 14th May 2025 10:33pm
Q86ARR
They just clip on. So pull old one off and clip new one on
Post #1068304 22nd May 2025 8:56pm
lightning
They need a small amount of modification to fit a regular Defender. The Driver side one fits okay but behind the vent there's a fluid reservoir and some sound insulation.
So you need to make a plastic cover to fit inside the vent, l used 1mm plastic sheet which can be cut to size with ordinary scissors, and siliconed it into the vent.
The passenger side one needs part of the edge of the vent inside cutting down otherwise it hits the air intake.
It's obvious when you offer up the vent and you can compare it with the original one.
Post #1071764 19th Jul 2025 11:14pm
