![]() | Home > For Sale & Wanted (L663) > [SOLD] OCTA Side Vents |
| JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7946
Is it not worth keeping, should you ever remove the snorkels and return to original? Maintain value. James
| lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3528
Trying to decide if these would enhance the look of my Tasman Blue D250 Commercial. Anyone know how they are attached and how easy it is to change them?
| ruben Member Since: 04 Feb 2021 Location: ASTURIAS Posts: 381
I think they can look very good..only remember that this are both functional and you, in your D250, have one of them covered, you should find a way to keep it that way...That's your biggest obstacle I think!! Although they may not be in a block, it is only the grille cover, I am talking nonsense!!🫨
Good luck! Defender 110 SE I6 D250 23MY ExDiscovery 3 TDV6 SE |
| Bigtym Member Since: 06 Apr 2025 Location: Derbyshire Posts: 5
Is collection possible? If so wheres the location. Thanks |
| Q86ARR Member Since: 28 Feb 2017 Location: Earth Posts: 44 |
They just clip on. So pull old one off and clip new one on |
They need a small amount of modification to fit a regular Defender. The Driver side one fits okay but behind the vent there's a fluid reservoir and some sound insulation.
So you need to make a plastic cover to fit inside the vent, l used 1mm plastic sheet which can be cut to size with ordinary scissors, and siliconed it into the vent. The passenger side one needs part of the edge of the vent inside cutting down otherwise it hits the air intake. It's obvious when you offer up the vent and you can compare it with the original one. |
