![]() | Home > Maintenance & Modifications > Diesel Heater Box |
| jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 1001
Looks neat
Jim |
| TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1366
Hurray - no MDF!
| diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218
Reminds me of an old lightweight I once had, was an ex RM arctic one, and had the remnants of a mahoosive heater between the front seats with 4 pipes like you're fitting going off around the vehicle.
| Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2347
Looks like a good job well done.
Looking forward to seeing the next phase 👍 |
| excossack Member Since: 22 Feb 2012 Location: North West Posts: 6043
Looks good. I wonder if the 4 port head would fit a Eberspacher? 1999 Defender TD5 110
| bodstruck Member Since: 09 May 2020 Location: Wiltshire Posts: 1007
Should fit, I think they are pretty much the same size. For less than a tenner it may be worth a shot?
Deffo worth a shot. My heater lives under the rear seats and for a while I have been pondering a way of getting heat into the front foot wells as well as the rear footwells.
Getting the heater pipes over the middle row seat carpet without being in the way is the issue. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
| MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 692
Just be carefull, not to overheat it, because 2 of your heater outlest are next to the heater inlet - it can make a "short circuit", when hot air is passed again into the heater. "Drobek" = The Small One - Discovery 2, "Blufínek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
Good point, thanks.
The reason for the swivel heads is to ensure I can direct heat away from the inlet. Also, I don't really anticipate it being on for long periods, just to warm the thing up in the first place really. Once the cabin is warm (and the engine) the std heater does tend to keep up. I'll see how we go. Worse case I remove it and redesign, it has only cost £15 thus far. |
| revd Member Since: 20 Apr 2024 Location: England Posts: 297
neat. a diesel heater is one of the best mods for Defenders
I used the Mudstuff box and directed the heat back through the bulkhead (110 Hardtop) - I was surprised how quickly the heat travels forward to the front seats. |
| SimonR Member Since: 28 Jun 2012 Location: Horsham, West Sussex Posts: 77
I like your solution with outlets front & rear.
Click image to enlarge I fitted mine in the battery box. If you buy a 2kW heater - it fits quite neatly! A 4kW doesn't - ask me how I know! |
Top tray constructed and the whole thing covered. I did buy vinyl to cover it but didn't like the finish so I used some leftover stretch carpet from the headlining.
I contemplated adding a closing lid but I like having an open tray for stuff. I wil also make another lid that can be interchanged that has a cubby box on it but a job for later. I have the cubby ready. Just need to get round to fitting the heater now then I can install the whole thing Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
BTW, if anyone wants a new, unused Mudstuff heater box, then I have one here.
£60 posted |
| All times are GMT |
