Home > Technical > Cooking Gas System
Steve_overland
United Kingdom 1997 Defender 110 300 Tdi HT Chawton White
Cooking Gas System
Has any one got any experience of fitting a gas kit (for Cooking) to the underside of a vehicle please. Similar to the type fitted to caper vans etc....
this sort of thing:
 @steve_overland on Insta.
110 expedition vehicle with pop roof
Post #1066838 2nd May 2025 1:38pm
landy andy
It’s a lot of money compared to fitting a refillable cylinder, but I assume you want it mounted under the vehicle.
I would suggest talking to these people who have very helpful, and know their stuff
https://autogasshop.co.uk/product-category...gas-tanks/
They do a small 16 ltr under tank.
Post #1066840 2nd May 2025 1:46pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Another option, (assuming its only to take advantage of LPG being cheaper than bottled gas, and not because you want to free up space from carrying gas cylinders) is these refillable gas cylinders
https://www.gaslowdirect.com/product-categ...cylinders/
Refilled from the LPG pumps at fuel stations. Fairly high (compared to regular gas bottles) initial outlay, but easily transferable should you swap vehicles/motor home/caravans. I believe you'd also maintain a regular gas connection should the worst happen and you run out in an area with no LPG available so you could throw on a regular gas bottle. 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #1066843 2nd May 2025 2:05pm
andy63
I have fitted a few gas systems into camper / motorhomes ...
pretty well all types from refillable, exchange , and underslung tanks...
nothing particularly difficult about it , and as long as you do the necessary leak testing on commissioning you should be fine...
with the refillable or underslung the issue will be where to mount the fill point and make sure its secure as the log pump nozzles are a fair lump of metal , and wear gloves when filling...cold burns are easily picked up when disconnecting Rolling Eyes
few pictures , that might give you an idea or two....
the exchange cylinders in the steel gas locker , I don't believe are available any more..I think 6kg is the smallest exchange calor do now..
Post #1066849 2nd May 2025 2:46pm
andy63
just found a couple photos of a cut away of an underslung tank... posted just for anyone who is interested Very Happy
Post #1066854 2nd May 2025 2:54pm
landy andy
I’m sure you know, but. Don’t be cheeky and get a deal on a gas tank from a gas powered car. You want a vapour tank, not a fluid one.
Post #1066855 2nd May 2025 2:58pm
Steve_overland
Wow I'm so chuffed with the responses... cheers all
I should probably say, I want it as external space is a bit lacking for a normal cylinder to be mounted and don't want on roof because of the all cab pop top.
The two Andy's - are these system compatible with uk and European systems??
Post #1066870 2nd May 2025 5:41pm
landy andy
Any refillable system is suitable with European systems with a pack adapters that you buy.
This sort of thing.
https://autogasshop.co.uk/product/lpg-fill...pg-filler/
Post #1066876 2nd May 2025 6:22pm
Steve_overland
thank you sir..... so I Guess I need to get the tape measure out.... @steve_overland on Insta.
Post #1066884 2nd May 2025 7:04pm
landy andy
And the wallet Rolling with laughter Rolling with laughter
Post #1066890 2nd May 2025 7:20pm
Steve_overland
MMMM yes .. let the moths fly...... Rolling with laughter @steve_overland on Insta.
Post #1066957 3rd May 2025 6:34pm
