![]() | Home > Puma (Tdci) > Puma aircon puzzle |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6046 ![]() ![]() |
Do you know if it has gas in the system? Or if/when you’ve have it regassed
Nelson211005 Member Since: 02 May 2025 Location: Scotland Posts: 2 ![]() ![]() ![]() |
Sorry, have no idea about gas levels and as far as I know it has never been re-gassed but couldn't swear to that.
It just seemed strange that when the aircon button was activated the fan was on low speed regardless of whether the speed dial was on 0,1,2 or 3, which seems to point to a fuse/relay or both perhaps. Once my new fuses arrive I will swap out R28 just in case, then if no joy I'll try to get the problem diagnosed - all this is way beyond my skill set !!!!! Thank you for your help. |
90 Dreamer Member Since: 13 Jul 2019 Location: Oop North Posts: 2308 ![]() ![]() ![]() |
fairly sure mine has always done that......2016 XSi
Johan_B Member Since: 20 Sep 2024 Location: Gothenburg Posts: 159 ![]() ![]() ![]() |
The coupé fan will always be on when A/C is activated. This is to prevent freezing in the heater matrix.
Linds Hanson Member Since: 16 Jan 2021 Location: Cornwall Posts: 537 ![]() ![]() |
The fan runs slow whenever the AC switch is pressed but should speed up once speed 2 or 3 is selected.
