![]() | Home > Technical > l230 front output flange bearing |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3680 ![]() ![]() ![]() |
I think I have a bit if lift in my transfer box front output shaft bearing, any tips on changing it before I start? DEFENDER 90 TDCI XS,
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 683 ![]() ![]() ![]() |
They are a single ball race bearing, they do have some slight up and down/ side to side play from new
thanks oldowner, I took the shaft off and then couldn't find anything wrong with the Transfer box, greased the shaft put it all back together with new nuts and bolts, will ignore it for a bit and see what happens DEFENDER 90 TDCI XS,
Will@LRW Member Since: 04 May 2019 Location: UK Posts: 231 ![]() ![]() ![]() |
I had play recently and presumed it was the bearing, but it turned out to be a loose nut. Now the grinding noise above 55mph has gone! LR Workshop
New parts illustrations https://www.lrworkshop.com/diagrams/land-r...ed-corners Find a Defender's history and spec: https://defender.lrworkshop.com |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6218 ![]() ![]() ![]() |
When I rebuilt a t/box some time back, I fitted a new front bearing and it had just as much play as the old one.
