Home > Technical > l230 front output flange bearing
LR90XS2011
I think I have a bit if lift in my transfer box front output shaft bearing, any tips on changing it before I start? DEFENDER 90 TDCI XS,
Post #1066748 1st May 2025 6:38am
Oldowner
They are a single ball race bearing, they do have some slight up and down/ side to side play from new
Post #1067244 7th May 2025 7:44pm
LR90XS2011
thanks oldowner, I took the shaft off and then couldn't find anything wrong with the Transfer box, greased the shaft put it all back together with new nuts and bolts, will ignore it for a bit and see what happens DEFENDER 90 TDCI XS,
Post #1067246 7th May 2025 7:53pm
Will@LRW
 1997 Defender 110 300 Tdi CSW Alpine White
I had play recently and presumed it was the bearing, but it turned out to be a loose nut. Now the grinding noise above 55mph has gone! LR Workshop
New parts illustrations https://www.lrworkshop.com/diagrams/land-r...ed-corners
Find a Defender's history and spec: https://defender.lrworkshop.com
Post #1067304 8th May 2025 4:57pm
When I rebuilt a t/box some time back, I fitted a new front bearing and it had just as much play as the old one.
Post #1067309 8th May 2025 6:10pm
