![]() | Home > General & Technical (L663) > Height of Roof Rails and ladder |
WizzardPrang Member Since: 05 Nov 2020 Location: Hertfordshire Posts: 181 ![]() ![]() |
Roof rails and the side mounted ladder are below the shark fin, however roof cross bars add a bit more. My Defender has air suspension and I've measured as follows:
If my memory serves correctly, Height clean: 1970mm With roof cross bars: 2010mm However with Access Height selected (you can lock it down for car parks): Access Height: 1950mm With cross bars: 1990mm Current vehicle: 2020 Defender 110S Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2 Insta: wizzardprang |
fatphoca Member Since: 31 Mar 2025 Location: Cloud Nine Posts: 5 ![]() ![]() |
Thank you. Exactly the info I need.
I wonder if the Plumb roof rails and rack are lower or higher than the LR ones? |
