Home > General & Technical (L663) > Height of Roof Rails and ladder
fatphoca
Can someone let me know if adding roof rails and a ladder will increase the overall height of the Defender or will it still be lower than the shark's fin? Most carparks I use have a 2.0m height limit so I'm worried that the rails and ladder will exceed this. Thanks!
Post #1065835 19th Apr 2025 9:46am
WizzardPrang
Roof rails and the side mounted ladder are below the shark fin, however roof cross bars add a bit more. My Defender has air suspension and I've measured as follows:
If my memory serves correctly,
Height clean: 1970mm
With roof cross bars: 2010mm
However with Access Height selected (you can lock it down for car parks):
Access Height: 1950mm
With cross bars: 1990mm Current vehicle: 2020 Defender 110S
Gone: Defender 90 HT 200Tdi, Discovery Sport, Freelander 2
Insta: wizzardprang
Post #1065905 19th Apr 2025 10:29pm
fatphoca
Thank you. Exactly the info I need.
I wonder if the Plumb roof rails and rack are lower or higher than the LR ones?
Post #1065910 20th Apr 2025 7:46am
