![]() | Home > Puma (Tdci) > Rumble and vibration in 5th/6th Gear |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21015 ![]() ![]() |
Prop UJ’s, check their condition, regrease.
If that makes a difference that’s something to look at, possibly replace, check slider as well, but no need to take apart. If it’s power wise it’ll be VCV, but the VCV failing will produce a lack of power, there shouldn’t be much else symptoms wise at that speed. It could be imbalanced grease over time in the UJ cups as well. Check tyre treads for excess grit or stones, that can cause imbalance. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2526 ![]() ![]() |
You will need to start discounting things to identify where the issue is, so other things to check.
1. Wheel bearings 2. Brakes , to see if there is a slight binding. Are discs very hot after a high speed journey. Ps better to use a cheap infrared thermometer than touch with fingers ! 3. Swivels for damage and grease level. 4. Diffs , especially front Diff 5 CV joints |
