Home > Technical > What’s this noise?
Page 2 of 2 <12
Diesel Power
United Kingdom 1992 Defender 110 300 Tdi CSW Java Black
Thanks guys
I've not had the vehicle long and I've been busy going through it upgrading things but I've not managed to get to the props before this happened.
New rear prop being sorted. It's still within the 3 month warranty period so it's going back to be sorted.
The car is pretty much new underneath now apart from the props and rear diff. Typical that it broke before I got to upgrading it.
Thanks for the advice.
Post #1065452 14th Apr 2025 9:07am
If you can, get both Props replaced, because if you do one, the other will have a failure not long after.
When I had a UJ go, it was the rearmost on the rear Prop, the front Prop was fine, but I did the UJ’s on that too, as I knew that if I did just the rear, the front wouldn’t be long away.
In my case, the Props were fine, so I could replace all the UJ’s, but sadly on yours the spider, has eaten through the roller bearings, and the bearing cup and into the yolk.
I’ve not had any issues at all with GKN’s UJ’s fitting, so they are pretty good.
Good thing with the warrantee Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1065453 14th Apr 2025 9:27am
Diesel Power
It looks like they’ll have to replace the rear prop as others have said.
For the front prop, is it worth opting for a Gywn Lewis double cardan as I’ve read they’re good for NVH. Or would a standard GKN be the best for on road manners?
Post #1065522 14th Apr 2025 8:50pm
If you haven't had any problems with a standard front shaft you're unlikely to notice much difference (other than.to your wallet) from the DC front shaft. I have one and I think there are improvements but the difference is not huge on a standard-ish vehicle.
Post #1065544 15th Apr 2025 7:08am
landy andy
I personally would stay well clear of DC props, unless I really really needed one. They are far more difficult to work on kerbside if you have issues and the cost is far higher for them. And in my experience they don’t have the ability to grease most of them.
Post #1065550 15th Apr 2025 7:44am
GL ones are fully greaseable but changing a UJ (even at the simple end) is an absolute nightmare!
Post #1065552 15th Apr 2025 8:11am
landy andy
We had a vehicle running a DC last year in Wales. His DC prop poo’d its self and runined his trip as could rebuild whilst camping. Keep it simple. Thumbs Up
Post #1065557 15th Apr 2025 9:17am
Diesel Power
Hi guys
New prop installed. The Hardy Spicer OEM one. Much better now although I can hear some noise from the rear diff. I noticed the pinion seal is leaking.
Not sure whether to try and find someone to swap out the diff in this axle for an Ashcroft ATB or swap to a Puma axle? I’ve already changed everything else on the axle so it’s probably less hassle to keep my current axle although I haven’t managed to find anyone who will do the work around the Midlands.
Post #1065877 19th Apr 2025 5:20pm
Page 2 of 2 <12
