![]() | Home > Faults & Fixes (L663) > Soft Close Tailgate Issue |
pjeski Member Since: 25 Jul 2023 Location: Michigan Posts: 115 ![]() ![]() |
Try turning off the walk away locking on the pivi screen settings.
MiltonMan Member Since: 07 Mar 2024 Location: Brisbane Posts: 18 ![]() ![]() |
I have a new 2025 90 with soft close, I’ve found similar, I now hold the little door button in the handle in until opened, seems to work.
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1132 ![]() ![]() |
If it’s any consolation it might be normal. My 21 model which has a factory fitted soft close door does this occasionally. It seems to get stuck in cycle and fails to let you open. As said, a quick cycle of the lock then unlock resets it. 2021 Defender 110 X-Dynamic HSE D300 MHEV
1966 S2a 109 aka Betsy |
