![]() | Home > Td5 > TD5 leak - PAS pump? |
Craig772 Member Since: 23 May 2022 Location: Cannock, Staffordshire Posts: 75 ![]() ![]() ![]() |
![]() Click image to enlarge Hi all, my ‘dry’ 2000 TD90 has finally become incontinent. The source of the puddle on the drive appears to be what in think is the PAS pump. Is that correct? Is this a common item to fail or is it more likely to be a gasket or union? https://www.instagram.com/roxi_defender90/ |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 567 ![]() ![]() ![]() |
Yes that's the Power steering pump, I've recently changed mine due to the same leak as yours.
I tried resealing the union to no avail Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
Hazza Member Since: 10 Jan 2011 Location: North Yorkshire / Leeds Posts: 244 ![]() ![]() ![]() |
They're remarkably easy to rebuild. There's a full kit on eBay with seals and gaskets. It seems the main seal between the two halves fails and then you get a leak. 1990 Defender 110 200TDI Camper - now converted to Td5 power
