Home > Td5 > TD5 leak - PAS pump?
Craig772
United Kingdom 2000 Defender 90 Td5 CSW Oslo Blue
Hi all, my ‘dry’ 2000 TD90 has finally become incontinent. The source of the puddle on the drive appears to be what in think is the PAS pump. Is that correct? Is this a common item to fail or is it more likely to be a gasket or union? https://www.instagram.com/roxi_defender90/
Post #1064997 8th Apr 2025 2:22pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Yes that's the Power steering pump, I've recently changed mine due to the same leak as yours.
I tried resealing the union to no avail
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #1065202 10th Apr 2025 9:06am
Hazza
United Kingdom 1990 Defender 110 Td5 HT Bronze Green
They're remarkably easy to rebuild. There's a full kit on eBay with seals and gaskets. It seems the main seal between the two halves fails and then you get a leak. 1990 Defender 110 200TDI Camper - now converted to Td5 power
Post #1065261 10th Apr 2025 9:15pm
