![]() | Home > Puma (Tdci) > Fuel filter orientation |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 823 ![]() ![]() |
they can be a pain to twist and lock into position so you are confident that its right...
and because I know this im careful to take note of the orientation of the old filter when removing it and dropping it out of the head...and make sure the new one is offered up in the same orientation... you usually feel the little give when its lined up and ready to push in, but as said the twist to lock can be a pain, and diesel on can and hands doesn't help ![]() |
Waka56 Member Since: 08 Nov 2023 Location: Hamburg Posts: 171 ![]() ![]() |
I find it even worse removing it to be honest, to scared to pull sometimes as I'm never sure if that's the unlocked position
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20964 ![]() ![]() |
It’s a bayonet fitting, but iirc you are righ, a more clear indicator of it being locked in the correct place in a visible location would have been preferable. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2494 ![]() ![]() ![]() |
By the way, I got this picture for those curious how this wonderful plastic crap looks inside
![]() Click image to enlarge Puma 110" SW ............................................................. Earth first. Other planets later |
Pat Member Since: 05 Dec 2016 Location: Somewhere new! Posts: 371 ![]() ![]() |
Informative thread.
I haven't experienced the joy of a Puma fuel filter change before, but plan to change my filter in the next day or so. It sounds as if it may take a few attempts to get the new filter element sitting correctly, so I'm wondering, .... when the old filter is removed, does diesel continue to drain away from the filter housing or does it drain for only a short while and then stop? Trying to figure out what size container might be needed to collect the draining diesel. It started with a kiss, never thought it would come to this. SIII CSW Safari, limestone, (JAC 914N). Where is she now? It's not a car, it's a way of life! |
Most if not all the fuel will be contained in the filter. Maybe you can drain it through the drain plug before removing the filter. Puma 110" SW
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3605 ![]() ![]() ![]() |
LandRover installed it on the wrong side of the chassis for the Tdci... but the fuel cooler is on the correct side.. but I guess no one from the JLR engineers could figure that out as thats what always was done for the Td5. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Thanks for the response. So, on removing the old filter, the only fuel spillage comes from the filter itself and there's no continuous flow of diesel? It started with a kiss, never thought it would come to this. SIII CSW Safari, limestone, (JAC 914N). Where is she now? It's not a car, it's a way of life! |
Johan_B Member Since: 20 Sep 2024 Location: Gothenburg Posts: 140 ![]() ![]() ![]() |
That is how I remember it. No spilling of diesel whatsoever. Ideally the changeover shouldn’t take more than a few seconds and it is definitely not shooting out diesel.
Don’t forget to pre fill the fuel filter right to the brim before fitting.
![]() ![]() ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 788 ![]() ![]() ![]() |
Is there a better, metal version of the head the filter screws into? I'm not very confident of that plastic one we're using right now.
Pioneer has one for the TD5 but I don't think we can use it with the TD4 Pumas. No Better Friend, No Worse Enemy |
So, is it just "guess work"/"fingers crossed" as to whether a new filter is seated correctly?
Did a fuel filter change for the first time today, required a strap wrench to remove the old and a slight struggle to get the new one in. Just a dribble of diesel. Instructions on the new filter - twist until there's a "click". I didn't get any kind of click, but I cant get any further twist. So, I'm left wondering, is the filter tightly in place or will it drop out first time I hit a bump in the road? .... the fun and games of DIY servicing! ![]() Should I have got a "click"? It started with a kiss, never thought it would come to this. SIII CSW Safari, limestone, (JAC 914N). Where is she now? It's not a car, it's a way of life! |
