Home > Puma (Tdci) > Fuel filter orientation
MatLandy
France 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
Maybe I've been overthinking this ... but I had a fight changing the fuel filter on my Puma and tried to understand why it required so much force to slide the new filter up into the mounting head (before turning it into the locked position).
So here are my findings ... hopefully it makes sense.
The lock / unlock signs on the filter header are located on the side against the chassis, hence not visible.
This is not very smart of Land Rover. Picture below of the lock / unlock signs. If these were visible by the individual changing the filter, well, it would have helped a lot to ensure new filter is installed 100%
The fuel filter has 3 lugs, that needs to be aligned with the corresponding recess on the header when pushing the filter up to install it, and before rotating it clockwise to lock it. This gives 3 possible positions to insert the filter in the header, each one 120 degree from the other.
But only 1 of the 3 position is correct and properly aligns the lock sign on the filter with the lock sign on the header. The filter also has raised “keys” (or bulge) on the upper unpainted metal area. There is one square "key" (or bulge), that "key" needs to be properly aligned with corresponding recess on the mounting head when offering the filter up in the head. Otherwise it's a fight to slide the filter up.
I made a corresponding white marker on the mounting head to align with the square "key" (or bulge) on the filter for the next time I change it. Another picture to visualize what I'm trying to explain.
/Mat
Post #1063964 26th Mar 2025 5:09pm
andy63
they can be a pain to twist and lock into position so you are confident that its right...
and because I know this im careful to take note of the orientation of the old filter when removing it and dropping it out of the head...and make sure the new one is offered up in the same orientation...
you usually feel the little give when its lined up and ready to push in, but as said the twist to lock can be a pain, and diesel on can and hands doesn't help Laughing
Post #1063965 26th Mar 2025 5:48pm
Waka56
Germany
I find it even worse removing it to be honest, to scared to pull sometimes as I'm never sure if that's the unlocked position Laughing Making my Defender great again. (Or trying to at least xD)
Post #1063966 26th Mar 2025 5:54pm
It’s a bayonet fitting, but iirc you are righ, a more clear indicator of it being locked in the correct place in a visible location would have been preferable. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1063973 26th Mar 2025 7:51pm
MK
By the way, I got this picture for those curious how this wonderful plastic crap looks inside
 Puma 110" SW
Post #1064018 27th Mar 2025 12:06pm
Pat
Wales
Informative thread.
I haven't experienced the joy of a Puma fuel filter change before, but plan to change my filter in the next day or so.
It sounds as if it may take a few attempts to get the new filter element sitting correctly, so I'm wondering, .... when the old filter is removed, does diesel continue to drain away from the filter housing or does it drain for only a short while and then stop? Trying to figure out what size container might be needed to collect the draining diesel. It started with a kiss, never thought it would come to this.
SIII CSW Safari, limestone, (JAC 914N). Where is she now?
It's not a car, it's a way of life!
Post #1070939 6th Jul 2025 9:15pm
MK
Most if not all the fuel will be contained in the filter. Maybe you can drain it through the drain plug before removing the filter. Puma 110" SW
Post #1070940 6th Jul 2025 9:25pm
Dinnu
Re: Fuel filter orientation
/Mat
LandRover installed it on the wrong side of the chassis for the Tdci... but the fuel cooler is on the correct side.. but I guess no one from the JLR engineers could figure that out as thats what always was done for the Td5. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1070970 7th Jul 2025 2:08pm
Pat
Wales
Thanks for the response.
So, on removing the old filter, the only fuel spillage comes from the filter itself and there's no continuous flow of diesel? It started with a kiss, never thought it would come to this.
Post #1071004 7th Jul 2025 9:20pm
Johan_B
Sweden 2007 Defender 110 Puma 2.4 CSW Tonga Green
That is how I remember it. No spilling of diesel whatsoever. Ideally the changeover shouldn’t take more than a few seconds and it is definitely not shooting out diesel.
Post #1071005 7th Jul 2025 10:12pm
Don’t forget to pre fill the fuel filter right to the brim before fitting. Idea
Thumbs Up ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1071006 7th Jul 2025 10:21pm
HardCharger
Is there a better, metal version of the head the filter screws into? I'm not very confident of that plastic one we're using right now.
Pioneer has one for the TD5 but I don't think we can use it with the TD4 Pumas. No Better Friend, No Worse Enemy
Post #1071014 8th Jul 2025 8:53am
Pat
Wales
So, is it just "guess work"/"fingers crossed" as to whether a new filter is seated correctly?
Did a fuel filter change for the first time today, required a strap wrench to remove the old and a slight struggle to get the new one in. Just a dribble of diesel.
Instructions on the new filter - twist until there's a "click". I didn't get any kind of click, but I cant get any further twist. So, I'm left wondering, is the filter tightly in place or will it drop out first time I hit a bump in the road? .... the fun and games of DIY servicing! Smile
Should I have got a "click"? It started with a kiss, never thought it would come to this.
Post #1071948 21st Jul 2025 9:38pm
