Home > Puma (Tdci) > Leaking Oil return pipe turbo
mifa
2007 Defender 90 Puma 2.4 PU Tonga Green
God evening
I got two questions I need some forum help os please;
I´m in the ongoing process of trying to keep the oil inside my 2007 Puma engine, which can be quite frustrating to become ready for our “MOT”.
Apparently leaking around the oil pan, when driving blowing oil to the bellhousing, and located one of the leaks to the right of the engine at the bottom end of the turbo oil return line.
Have been a lot better since I recently replaced the severely leaking injectors and fitted at Provent catch can as well, but still leaking.
From pictures of a new pipe, is seems like an O-ring is fitted to the bottom end, but I cannot find this as a part number.
Is the procedure to replace the pipe with a new gasket at the turbo end of the pipe or just replace the o-ring?
Second, in the picture, the green connector fitted to the engine but not wired, which I assume it’s should be; what is that for?
I have no error codes, and the engine runs brilliantly in general (I know—but Puma brilliantly Big Cry
Michael
Post #1063778 24th Mar 2025 8:00pm
swt
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
On the second question re electrical connector:
https://www.defender2.net/forum/post20970.html
Post #1063805 24th Mar 2025 11:09pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
On the first question, the o-ring is not available separately. That said, I'm sure you could match one up once you have it apart. Make sure you use an o-ring made of an oil-proof material.
Post #1063872 25th Mar 2025 6:55pm
mifa
Thanks for taking the time to reply!
My thought regarding the green plug was also to keep my fingers away, as everything works and thanks for the reference to the other thread, I hadn't found it.
My thought was also to try an o-ring from the local hardware store, a new tube in a blue bag costs 110 Euro, so there is room for trail and error
Michael
Post #1063893 25th Mar 2025 9:10pm
