![]() | Home > Puma (Tdci) > Leaking Oil return pipe turbo |
| swt Member Since: 24 Aug 2018 Location: Cumbria Posts: 167
On the second question re electrical connector:
https://www.defender2.net/forum/post20970.html |
| jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 282
On the first question, the o-ring is not available separately. That said, I'm sure you could match one up once you have it apart. Make sure you use an o-ring made of an oil-proof material.
| mifa Member Since: 16 Dec 2022 Location: Denmark Posts: 19
Thanks for taking the time to reply!
My thought regarding the green plug was also to keep my fingers away, as everything works and thanks for the reference to the other thread, I hadn't found it. My thought was also to try an o-ring from the local hardware store, a new tube in a blue bag costs 110 Euro, so there is room for trail and error Michael |
| All times are GMT |
